Yesterday ago I noticed that my Pentair Intelliflo VSF pump was running at the maximum system pressure limit. I was not sure at the time how long this had been running like this but the pump felt hot so I turned it off for a while, then started it to run manually at a slow flow for a while. It later resumed it's next scheduled programming, stopping and starting just fine. Today around the same time it was back at it - at max pressure.
I dug deeper and discovered that my daytime scheduled programed flow setting in the pump memory had changed from 35GPM to 140GPM which is the pump maximum and obviously far too high to sustain. I changed the setting back to 35GPM and all seems fine.
But my question is what could have caused the pump to change a setting like this. Nobody had touched the pump for many months so it was not any sort of human error.
Does anyone have any ideas? Thanks.
