Hi,
I backwashed our DE filter today, which is something that I've done many times before. Our system has a separation tank to collect the used DE when we backwash. I have attached a picture that shows our filter as well as the tank next to it. When I get ready to backwash, I turn the pump off, grab the black T-shaped handle on the pipe coming out of the filter, twist it 90° and pull upward to open flow between the filter and the tank. I turn the pump on, run it for about a minute, then shut it off. I push the T-shaped handle all the way down and twist back 90° to where it was. This was what I did today, as usual. Normally, when I turn the pump on again, things run just fine. Today, when I turned the pump back on, I noticed that the water in the pump strainer was very low (was water tight before the backwash), the pump was not as loud as usual, and the pump strainer wasn't filling with water as usual. I continued to run the pump for a few minutes, and never saw a change in the water level in the pump strainer area.
The filter also shows 0 psi now. Any ideas on what could be causing this?
I first attempted to do the backwash yesterday, but had a problem with the tank lid coming off. We determined that the rubber gasket was worn and needed to be replaced. I got a new gasket yesterday, put the lid back on and clamped it tight. It was getting too late to backwash yesterday, so I made sure that the flow from the filter to the tank was closed so that the pool could run normally last night (which it did). I let some air bleed out of the tank before doing the backwash today. Could this have had any effect on the pump problem that I have now?
