Dear pool professionals,
In the positions of Multi-Valve, Recirculation, Waste, Rinse, Backwash, water flow (in and out ) is great. No leaking in any valves, pipes, and so on.
However, in the position of Filter, water flow looks OK for 5-10 minutes and then the pump pressure goes up around 25 psi (normally below 20 psi), water flow of returns becomes very weak as well as water sucking is very weak in a skimmer. After a few times of Backwash, cleaning filter elements, relief of air by air valve and change in DE powder brand, water flow is still weak or almost no flow but Recirculation still works great.
Please help me....
Thank you
Please help me....
Thank you
