mas985 said:
Head is not a constant and it depends upon the flow rate in the plumbing which in turn depends upon the pump attached to the plumbing.
OK, I figured it was not quite as simple as I was trying to make it
mas985 said:
Also, the thing you need to focus on is each pump's energy factor (Gallons pumped per watt-hr consumed) because this is what determines the cost to run the pump. Here are the estimates that I can up with for each pump and assuming that you fix the pad plumbing and that is where most of your head loss exists (particularly the heater). All of these estimates are with solar engaged on high speed:
My concern is how much I am going to be able to "fix the pad" I have conceptualized a few different plumbing routing options and it seems that the best I might be able to do would be to remove 2-3 90deg fittings and add a bypass to the heater. Maybe the bypass will be the biggest factor, but I was hoping to be able to figure out how to eliminate a lot more turns, but where stuff comes out of the ground seems to be not helping. Any suggestions would be appreciated.
mas985 said:
WFDS-26/4: 60 GPM @ 71' of head & 1758 watts, 2.04 gallons/watt-hr, (6.4 PSI @ VRV)
WFDS-24/3: 58 GPM @ 66' of head & 1550 watts, 2.23 gallons/watt-hr, (5.7 PSI @ VRV)
SF-N2-1A: 52 GPM @ 55' of head & 1355 watts, 2.32 gallons/watt-hr, (4.1 PSI @ VRV)
SF-N2-3/4A: 44 GPM @ 40' of head & 1105 watts, 2.41 gallons/watt-hr, (1.8 PSI @ VRV)
You will note that there is less PSI margin for the smaller pumps so you will need to clean your filter before it rises that amount otherwise the VRV will open. I did not suggest the SF-N2-3/4A because the pressure margin at the VRV is too low for my liking.
Based on these numbers, the -1A flow rate seems close to the recommended flow rate of the solar (I guess being a little low will just slightly reduce the solar efficiency). My concern is that I may not be able to "fix the pad" as much as you may have assumed. Also, the Superflo numbers do not seem to match the flow curves from Pentair's website (which maybe also confused me). According to the chart, the -1A @ 55' is 45 GPM and the -3/4A @ 40' is 52 GPM ... so I still obviously do not "get it".
So let me be sure, with the -1A and solar, I would need to clean the filter before the pressure rises 4 PSI?
mas985 said:
Also, as you can see above, there is no WFDS-25. The next larger pump is the WFDS-26/4. But why do you want to go so big? That pump will cost about 15% more to run than the SF-N2-1A.
I realize there is no -3.4 / -25 I was trying to be funny (and failing apparently). Based on your previous recommendation of the -3, I thought if I could get something that size @ 230V that would be the way to go.
So, in your expert opinion, you think the -1A is adequate?
Does the -1-1/2A power consumption go up quite a bit for a marginal increase in flow rate?
Ignoring my possible electricity delivery limitation, would you still recommend the -1A (230V) over the -3 (115V)?
Thanks so much for you patience ... it is the little engineer in me that tries to understand (which is also why I originally was trying to learn you spreadsheet before it was removed :-D )
