Cold night, for us last night. I don't close pool in winter, I run the pump when <35F and this has worked good for several years. Sometimes have difficulty getting basket/pot lid to seal and prime. Power was going on and off about every 20 minutes early this morning. The lid NEVER seals and regains prime when power has been interrupted. I must fiddle with the o-ring seal every time to get it right. To make a short story long, (Ha!) I got tired of doing this several times last evening and turned the pump off. I am confident the flex line to Polaris and water in PVC pipes are frozen. The pump does work. Pump is still off, thin sheet of ice in pool, and it is about 21 degrees, but is supposed to warm to 32 about 2:00 p.m. Should I panic, (which I am good at), or try few of methods to get the system running again? I am considering a few options to get out of this mess. I look forward to your suggestions. Thanks.
1.) When temperature is warmest today, spray my garden hose water over pool equipment in hopes to thaw it?
2.) Build a crude tent with a tarp over equipment and use space heater?
3.) Do nothing, and wait until tomorrow when temperature should be over 40F, but below 15F following night?
