Have a 1.5 hp dual speed pump with a salt system and a sand filter. I noticed that recently when I go check it out the skimmer basket is floating and even though the pump is running the water doesn’t fill up all the wait to the top on the pump basket as it did before, this is actually only 1/3 full. The return jet is weak also and noticed a lot of small air bubbles.
I have done several backwash and rinse on the filter and try to prime and get any air it may have out without success. When I bypass the filter on recirculate the issue is still same with no changes. The filter pressure is fine. What do you think I should do? Thanks in advance.
