It's been a while since I've had to post (several years of thriving pool life thanks to this forum).
My pump, or maybe the motor, has finally bit it, I think. No water whatsoever coming into it from the Kreepy Krauly or the Skimmer, no pressure in the filter, and it doesn't seem to be any of the usual suspects — I double checked the gasket, cleared the baskets, and tried to clean out the impeller, made sure the water level was high enough. I am still trying to assess if there is a clog somewhere in the skimmer line, but I highly doubt it. Anyway, when reaching to the impeller to clean debris, I did notice that the cap that I usually reach through a little to pull debris out of the impeller now has a lot of play, suggesting to me that something is wrong with the pump itself.
The pump has been with the pool since before moving here (so, at least 6 years, and probably 10). Should I get a new one, or roll the dice on a repair that might delay getting a new pump installed in this weather? So far, I've gotten a quote for an Pentair Superflo that will cost me just under $1000, including installation (this is with rebates), by next Friday.
In case it doesn't show up below, I have a 13,000 gallon pool with a 1 HP Sta-Rite pump (MPR6E-147L) and Pentair Clean & Clear 320 Filter.
Thanks for any suggestions!
Matt
Matt
