I have the following pump: Jandy Pro Series Stealth Pump SHPF 2.0 and it is not so stealthy anymore! 5 years old. It is much much louder than it has ever been!!! Does this mean the pump and/or motor are on the way out? Flow and pressure in the pool seems to be happening as normal but is the loud noise due to the pump failing or the motor failing? Do I need to replace the just the failing pump or motor or is it recommended to replace the entire unit?
I'd appreciate any recommendations for replacement pumps. Since I live in NC and my pool is saltwater, I do not close it up during the winter. A variable or multi speed pump would be helpful to circulate water when it gets very very cold. Do I need to stay with the same brand (Jandy) to ensure the suction and discharge points are the same and will line up with current piping?
Finally, I am fairly mechanically inclined, but is this a project fairly easily done?
Thanks!
Mike
Thanks!
Mike
