Hi all, could you some help on making sure I do the right thing. After 11 seasons, the AO Smith motor on my Hayward inground pool pump started to not sound so good. Water is pumping just fine, but sounds like the bearings are starting to go, so I'm thinking just a replacement motor. I reached out to the pool company that put it in, and closes the pool every year, and he said if I can still get the motor, just do that, as anything over 1HP has to be a variable speed setup now. I told him the plate says it's 3/4hp, and I told him I could get the same rated motor. He mentioned that I would want to get it with a new impeller for that size motor. That the original motor came in a max rate and a full rate true horsepower, that was over 1HP.
But from what I'm seeing online, with the exception of the SF rating (1.65 vs 1.85 on the old one) and the enclosure type (DP vs ODP on the old one), everything else is the same. So what's the story, can anyone help solve it? I don't want to keep asking the contractor as he knows I'll do it myself, so figured I'd see if some folks here have some insights. Here's a pic of the current dying motor (and video) and a link to what looks like a drop in replacement, or very close. I haven't looked too much yet to see if I can find the exact motor, but this popped up when I put in the part number.
www.inyopools.com
Running Pump Clip
Thanks.
Century (A.O. Smith) .75 HP Full Rate Motor, Square Flange 56Y Frame, Single Speed - Model B847 - INYOPools.com
Century 3/4 HP Square Flange 56Y Full Rate Motor - B2847V1
Running Pump Clip
Thanks.
