Pump motor is starting to go, just replace motor or need a different impeller in wet end?
steveg_nh
851
Southern NH
Hi all, could you some help on making sure I do the right thing. After 11 seasons, the AO Smith motor on my Hayward inground pool pump started to not sound so good. Water is pumping just fine, but sounds like the bearings are starting to go, so I'm thinking just a replacement motor. I reached out to the pool company that put it in, and closes the pool every year, and he said if I can still get the motor, just do that, as anything over 1HP has to be a variable speed setup now. I told him the plate says it's 3/4hp, and I told him I could get the same rated motor. He mentioned that I would want to get it with a new impeller for that size motor. That the original motor came in a max rate and a full rate true horsepower, that was over 1HP.
But from what I'm seeing online, with the exception of the SF rating (1.65 vs 1.85 on the old one) and the enclosure type (DP vs ODP on the old one), everything else is the same. So what's the story, can anyone help solve it? I don't want to keep asking the contractor as he knows I'll do it myself, so figured I'd see if some folks here have some insights. Here's a pic of the current dying motor (and video) and a link to what looks like a drop in replacement, or very close. I haven't looked too much yet to see if I can find the exact motor, but this popped up when I put in the part number.
Running Pump Clip
Thanks.
I went through motor replacement recently on my TriStar, so this is fresh on my mind. Your old pump total HP (THP) is 1.39, while the one you're looking at is THP 1.24. The contractor is saying you'd need a smaller impeller to match the lower power motor, but I doubt it's a big enough difference. In my case, I replaced my single-speed 1 THP motor with a variable speed 1.3 THP (Century V-Green EVO). I also changed my impeller to a larger version at the same time. The VS motor was more costly than a single speed like you're looking at, but I'm running 24x7 at very low RPM. The electricity savings will quickly cover the extra pump cost, to say nothing of the joy of super-quiet operation. Lots of information in the archives here if you want to consider that route. Consensus is to go with a larger motor (and impeller) and run at very low RPM.
Thank you. I'm looking for the simplest solution, and while I'm very handy, impeller sizing and THP and all that isn't something I'm that similar with. Can I ask where on the nameplate you saw the THP of 1.39, or did you have to look it up?
I run my pump about 9 hrs a day, and it's been a bulletproof pool, so if I can just swap the motor, great. Not sure how hard it is to swap the impeller. Maybe it's obvious once the motor is removed, I'll have to see if I can find a video on YouTube. But if I can, I'll try to find a matching spec motor of 1.39 THP.
Talked to Inyo pools today, they were very helpful. They recommended a pump that is slightly larger in THP, and said I don't need to replace the impeller, but I could if I wanted to pick up a few more gallons per minute. They said it wouldn't hurt the larger motor to use the same impeller though. For $73 for another impeller, not sure it's worth it, as I would have the same water flow. If I understand it right, you would hurt a motor if the motor was smaller, trying to spin an impeller too large, but the other way around is ok when it's close. Is that right? This is what was recommended, appreciate if anyone has any thoughts:
Motor: Century (A.O. Smith) 1.0 HP Full Rate Motor, Square Flange 56Y Frame, Single Speed - Model B2848 - INYOPools.com
Seal Kit for TriStar pump: Hayward TriStar, EcoStar Pool Pump Saltwater Seal Kit By | By Pureline | GOKIT80SALT - INYOPools.com
Slightly larger impeller, if desired: Hayward Tristar Impeller with Screw, 1.5THP - SPX3210C - INYOPools.com
Thanks
I don't know why you wouldn't get a century or nidec variable speed motor, impeller and seal kit. Might be twice the price, but it would payback in a short period of time with reduced electricity costs.
What is the model # of the pump (not the motor)?
I was just looking at this new motor, and the amperage is significantly higher, so made me question this decision actually. The pump is a TriStar SP3207EE. Do you not have to change out the main body, thereby getting into the plumbing? If not, I may do this, and I assume I have to reprogram my AquaLogic system to know it's a VS motor.
Thanks for the help. I see two motors on that parts page, but there are others? How do I know which pump to pick? Looking at those VS motors on that page, they come with the matched impeller already. I'm at about $450 if I do the new single speed, impeller and seal kit already. The amperage draw of these VS motors is more than the single speed I have now, but I assume that's only when they are running at VS? My pool installer says he doesn't run them variable and just sets them to one speed. Wonder why he would do that.
You will spend less money on electricity...by a lot.
I run mine at 1400 RPM, 24/7, and it costs me less that $20/month.
I run at 2200 when I use the heater, it requires higher flow.
Here are the reasons to run your pump. Link-->Why you run your pump...
Cost comparison.
WOW! :) That is a lot. Geez. Any tips on how to select the right VS pump then? Seems like a no brainer honestly. My pool company quoted $1500 for a VS motor to fit my pump, plus installation. I'm more than capable of the install, and the owner knows it which is why he pointed me to look into a few things.
Will it interface with my AquaLogic system as a VS pump, so for things like when the heat pump is on, or the booster pump, it can automatically speed up? I can research it if you aren't sure (you've been super helpful already). I have to make sure I maintain the 56Y frame setup for the pump too, I believe. Need to understand that vs the 48Y showing on the EVQ225.
The "Y" part of the frame is the important part. That means square flange and the bolt pattern is the same for both. 48 vs 56 is just a diameter difference of the motor casing. I replaced my original 56Y with a 48Y V-Green EVO and it came with a little rubber spacer to take up the room on the original support bracket.
Reactions: PoolStored
So I think I have this all sorted out, but @PoolStored a follow up question for you...Talking to the rep at Inyo, he recommended the EVQ165 and not the 225, as he said the 2.25HP is too big compared to what I have now, and the 1.65HP is closer and just a bit more than the 1.39THP single speed pump I have now. You recommended the EVQ225, so wanted to see if you had an opinion on that. And Inyo has the pump as a kit, with new seals, properly sized impeller, and impeller ring (if I need it). And like you said @racingiron, the 48Y will bolt right up, just may need a small support at back of motor, but also may not.
The biggest benefit is going from SS to VSP. Any incremental benefit by going bigger is a smaller benefit.
He is wrong. Larger pump motors/impellers will move the same water at lower RPM vs. a smaller pump. A bigger motor will also be quieter because you are running lower RPM...and likely run cooler because they are running at lower RPM.
That's what I thought too. What he said was this "that is a much larger unit (the EVQ225), and your system may not be able to handle that size jump since you had a 3/4HP originally." I didn't know if he was thinking about pipes or stuff, or electric, but can't imagine it's an issue. I was trying to figure out flow rates and GPM of the two pumps, to see what is best for my 25,000 gallon pool. It's only $20 more for the 2.2HP VS motor.
I'm super surprised. INYO folks are usually pretty good, and I recommend them. (@InyoRich )
He is wrong. You would have no issues, if you get the right diffuser and impeller. Your system can handle it...we aren't going to be running full speed.
Rich helped me the first time (on picking out a replacement single speed motor), but the second time it was someone different when I inquired about variable speed options. I definitely felt more confident in Rich's answers. Good to see he's on here.
The 2.2HP kit is this one, but a different diffuser isn't included, unless that is the "impeller ring" that is mentioned in the list. Would that be it, or would my current diffuser be ok? It does come with the right sized impeller and seals.
I was wondering if the other rep was worried about exceeding max flow rates of my DE filter, possibly damaging the grids and stuff, but I would think that's a concern with Single Speed, not VS.
(Thank you too, the back and forth is super helpful in helping me understand, and be confident in my decision, I've been reading a bunch of threads as well)
