I'm having trouble with my Jandy JEP 1.5 HP Pump/motor slowing to a stop.
I've removed the pump/motor from my pool system.
The pump has some worn parts (a piece of palm frond got stuck in the diffuser and warped it, causing it to rub on the impeller).
My question is about the motor (I am not very familiar with variable speed pumps).
Should the motor (disconnected from the pump, impeller off) turn easily? there is an allen wrench hole at the end of the shaft (opposite end). When I turned the motor over (using the impeller still attached), it was hard to turn. Shouldn't I be able to spin it and have it spin fairly freely? I reconnected the motor (without pump) and it sounds rough at the start but runs like crazy!
I'm thinking the bearings are shot ... looking for some solid advice before putting out $1500 for a new pump motor combo.
Louie
Louie
