Hello,
This has been a great forum for me and my water has been awesome since I started using it. Thanks to all who have helped in the past.
I have a new issue I need help with.
I have an American Motors 1081 EB854 1.5hp single speed square flange (attached with 4 mounting bolts) motor that's about 3-4 years old.
It's running on a timer and yesterday I noticed the circuit breaker had tripped. Low and behold when I reset the breaker and tried to start the pump all I heard was a hum but the motor wouldn't start.
Having had experience replacing an old AO Smith motor I quickly figured it was a bad start capacitor. I didn't hear the bearings going bad, it seemed to be running fine before so I'm at least hoping it's a burnt out start capacitor. It's an easy fix I can do myself.
But here is the problem.
Having a salt water pool, I didn't realize I should have probably put silicone over the bolts before I attached the new motor (4 years ago). Now, the bolts are completely frozen solid due to the salt and completely corroded. I managed to get 2 out but that's it. So I can't even remove the motor to get to the capacitor.
Any ideas? I've tried WD 40 but 2 of these bolts are so corroded with salt they won't budge. In the future should I just lubricate with silicone the bolts to prevent this from happening again?
Here in Texas, unfortunately my motor is fully exposed to sun, rain, etc and these things just aren't made to last. I seem to burn one out every 3-4 years.
Any help you can provide would be appreciated.
Thanks all.
Thanks all.
