Have a new VS Pentair pump. When it ramps up in the morning it primes for a few min at 3000 rpm (about 10 psi at filter), then shifts to 2100 rpm for about 3 hours (about 6 psi at filter), all good so far, then I have it shift down to 1600 for several hours in the cycle, for the first couple of hours at 1600 all seems good, still good water flow at the returns (less then when pump is at 3000 or 2100 obviously but still a good flow and psi about 2)....but I notice after about 4+ hours at 1600 the water flow at the returns has greatly reduced and psi not registered at filter, if I look at the pump basket the water level has really dropped and water flow in is pretty low into the basket.....if I ramp the pressure back up to 2100 flow , flow returns, pump basket fills w/ water and psi and return water flow goes back to normal.
I've triple checked, no leak at pump (though I'm pretty sure I have a leak on the suction side piping (due to modest water loss /more then ambient water evap) that I just haven't been able to deal with yet. Is the lower rpm speed just not enough to keep pump primed w/ the probably suction side leak? until leak fixed should I just keep the rpm's above 2000? Never had a VS pump before so not sure if 1600 is too low or if it's just too low along w/ my prob suction side leak?
Thanks!
Thanks!
