Hi hopefully someone can help me. I have a hydro baker skimmer, and a closed main drain. When I hook up the vacuum I lose prime at the pump. Well at least I think I do. Normally my pump basket is full of water when the pump is running but as soon as I attach the vacuum the water in the pump basket goes half way down and water is still pouring in the pump but it's just not completely full. Is this normal ? I have changed the vacuum hose and we just changed the diverter on the Jandy valve bc it was leaking. It is still leaking by one of the screws bc the casing was cracked. We figured we will just epoxy that and just change the entire valve one day. So maybe that is still causing the issue. What do y'all think? TIA
