All my pool equipment is about 4 feet above the water level. The last few summers there has been a minor issue with air entering somewhere, because I would get bubbles from the return jets whenever the system started up for the day. Last summer, it was much worse, I would get 3-4 HUGE bubbles that broke the surface of the water when the system started. Any time I cleaned the pump basket and introduced air when taking off the lid, it meant that it lost prime for a few minutes. Aggravating, but not bad enough for me to want to get the pool company out to check. We just started up the system for this year and this morning I happened to be out there when the pump came on and heard it struggling to prime and the basket had no water. I waited almost 10 minutes. I remembered that the pool company said that upon initial start up it can help to close the skimmer returns and only pull from the main drain. I turned off the system, closed the skimmer drains, and it still would not prime. Turned off the system again, opened up the skimmer lines, and was going to open the pump lid and manually put some water in the pump basket to help, and when I opened the pump lid the basket was full of water (not sure how that happened). I quickly put the lid back on. Turned the system on, the basket drained, but then within a few minutes the pump primed and the system worked normally. My pool water level is fine so there's no leak. I do have a few minor drips in my system--the DE filter has a steady drip from the drain plug--and has been that way for a while. I've already checked the o ring, lubed it up, put plumbers tape on the threads, and all that helped slow it down. I do have a drip from a pipe near the site glass when I backwash but that also has been there for a long time. When I turn the system off, and put my ear against the DE filter, I can hear a "glub, glub, glub" like water makes when it's draining out. When I put my ear on the Multi-port valve, in all positions, I hear a soft gurgling/hissing noise. My pump was newly installed last year and never has air bubbles in the pump basket so I feel like it's not a suction issue. So what happens when the system is off? Is water leaving my pump and my filter both? What could be letting in so much air that the system is basically draining? Also, I hope the photo is ok, I basically have two skimmer lines, a main drain line, a Whisperflo single speed pump, a Pentair DE filter, an inline chlorinator we never use, and the Pentair gas heater. No water features or automatic vacuum. We have a slide that has a valve by it to let water flow but that's it.
