I have a slow leak dripping in the area indicated by the red arrow in the attached pic. Right by where the 4 bolts are that attach the pump basket to the rest of the pump. Is there an o ring in this area that might need to be changed out, or is this the shaft seal? I did just change the shaft seal 2 years ago so i would be surprised if it was that. I've never taken these 4 bolts off, as the only time I have taken the pump apart was when I changed the shaft seal, and that only required to take the pump apart from the clamp.
Does anyone know if there is an o ring in this location? I don't see any cracks in the housing either.
This is a Challenger Pac Fab 2HP pump.
