I cut and lowered the 3 feeds from the pool, but apparently my measurement was off. The feed to the pump is about a half inch too high to line up with the pump inlet.
I don’t seem to have enough room to cut it down another half inch because there’s no pipe left to cut, I don’t want to have to cut below the couplings I just attached on the 3 inlets and have to install new valves. Is mounting the pump on plywood even an option if I bolt the plywood to the slab, is there another option, or am I screwed and have to call someone to fix my botch job?
