I have a hayward variable speed pump put in 2 years ago with new PVC plumbing taking in water from pool.
In the past two years the skimmer filter on the pump would almost fill to the top each time started motor. The
skimmer filter would retain the same height of water (about 2 inches above top of inlet pipe) overnight.
Now the skimmer filter drains backward into pool every night so that the water level is roughly at the bottom of the inlet pipe.
No water leaks showing anywhere. Pump now takes 30 seconds to prime when I turn it on. Used to get to full pressure almost
instantaneously. Do I need new O-rings? new impeller? Any tests I can run to identify problem? Much thanks.
