So from what I've read on-line so far it sounds like I might have a cracked lateral or standpipe, but if that's the case I'm confused about something.
What's going on is that after I backwash and switch to rinse I get sand in the sight glass for a while, but it will eventually clear up. If I then switch to filter mode and turn on the pump sand will blow out of the outlet and into the pool for about 4-5 seconds and then stop.
What I'm confused about is that if I do indeed have a cracked lateral or standpipe then why does the sand stop blowing out after a little bit? What else might the problem be?
Thanks in advance for any help anyone can offer.
