So my pump busted last night and I'm waiting for the pool company to come tomorrow. I'm assuming I'll be down at least a few days. The forecast is hot with tons of rain so I'm worried about the pool going green on me. I've added a bunch of chlorine today and will brush at least once a day. I have two quesitons though and I'm hoping someone can assist:
1. Would it be beneficial to run a small pump (the one I use to drain the surface water off the winter cover) and direct the water back into the pool to keep it at least circulating a little bit? I have that set up now and the hose is spraying the pool water nicely back into the pool and seems to be moving the surface around at least.
2. When would I add more chlorine? I'm assuming I should get a test kit to keep an eye on the chlorine levels?
Sorry for the newbie questions.
Thanks!
Thanks!
