I have just had a 56,000 Litre outdoor pool built . The water is cloudy and when i checked the pump i found it to be 375 Watts which based on my calculations is too small. The pool Builder sent me a 600 Watt Pump to replace it however when i checked the Filter the Throughput Max is 180Litre Per Minute and the 600 Watt Pump Qmax is 350 Litre per Minute .
Should i install the New Pump with the Existing Filter or Install a Bigger Filter First?
my pool builder has supplied a bag of Poly Aluminium Chloride to help clean the pool . What is the correct dosage and application method ?
