Piston assemblies are readily available.Of course, if you cannot buy just what is broken,
That may work too…..Try putting some double sided tap on the grabber fingers.
The guts of them? Or does the whole shebang have to be replaced?Piston assemblies are readily available.
Guts onlyThe guts of them? Or does the whole shebang have to be replaced?
I would too. The connection to the heater is easy. I'd rebuild from the pump to the filter, and use a high temp union on the pump.The first is not OEM, the second looks to be. There's the labor of replacing the entire assembly to consider, but it's really only a few PVC welds to do. I dunno, I'd be tempted to replace the whole thing to new condition, considering it's old enough to have broken. Vs just sliding in a new push-pull gizmo. Hmmm. Just thinking out loud.
See, I'm with you. Why make it easy when you can make it hard!?I would too. The connection to the heater is easy. I'd rebuild from the pump to the filter, and use a high temp union on the pump. I'd also consider adding a diverter between the pump and the filter, so I didn't have to backwash if I wanted to pump to waste.
Pool plumbing repairs are like SCUBA diving. Knowing when not to attempt it is the most important skill of all!Oh I wish I had all of everyone’s knowledge and skills that have responded! I think I sadly will have to call the pool repair people $$$.
I really do appreciate the suggestions offered and all your help.
