Prowler 930 weird issue
Joe AC2RE
Active member
May 28, 2019
28
Long island, NY
So my Prowler 930 had an impeller Overload issue. I cleared the obstruction and now can’t seem to remove the error code, even when it resets, I tried several times. It seems to be cleared then comes back again. I checked the impeller and it’s working. Motor spins no problem.
In automatic mode it goes about 2’-3’ stops. The blinking(blue/purple?) light doesn’t flash on the robot just a couple a times with a Red one.
It works fine in manual (Blue tooth mode) picks up debris.
it there a certain way to clear the impeller overload error? Reset the mother board?
Thanks in advance
Hello Joe! :wave: I see it's been a couple weeks since you posted this question and no one has replied. I wanted to see if your cleaner is still showing those same symptoms and/or if you still needed some feedback from the forum. Let us know. Have a good day.
