Hi all,
Noticed that there is a vertical crack, about 3", about midway up the side of my Hayward ProSeries Filter.
Normally, I run my pump on a low speed, and at that speed, the crack barely drips.
This weekend I was running on full speed, and the crack is slightly more expanded, and leaks a small amount - maybe a about 250ml of water in 5 mins.
The labels on the filter are totally unreadable at this point, and the original pool documentation left by the previous owner shows the pool was built in 1995, with a "hayward 20" filter". There is no other documentation in the pool file about a replacement filter, so I suppose it's possible this is the original filter.
I may attempt a epoxy putty repair to last the season.
In terms of a replacement - is it possible to purchase only the filter tank as a replacement part? is this worth it? (seems painful to deal with removing sand/laterals, etc)
Would it be recommended to up-size the filter when replacing?
Is it possible/advisable to re-use the existing sand?
Thanks all.
Thanks all.
