Prologic "Check system no cell power 2" error
bacevedo
148
Chandler, AZ
I have a Hayward Prologic 8 control panel with the salt system. I just started getting an error in the last few days of "Check System No Cell Power 2". When I opened the panel there was a faint electrical burning smell.
In doing some research I'm not sure if this means I need a whole new PCB board, something just needs to be soldered, or something else.
Any troubleshooting tips you can give me?
I see new boards on Amazon n the $500 range. I feel confident I could replace it myself since I would just be replacing one with all connections already made. The biggest pain would be having to reprogram the entire thing again.
Bryan
Srqpoolguy
In The Industry
Feb 6, 2019
27
Sarasota fl
Yup this is a typical case of the diode or rather cuircut that powers the salt cell on the board. It’s a square black square in the top right hand side I believe (from memory). Look behind the board and see if the points of contact are burned. There is a way soilder a new one if so but after doing this twice the problem usually comes back. Replacing the pcb is a good bet against future burn outs. However if you are handy with a volt meter you can check other issues such as transformer voltage and even check the fuse on the board that is on the right hand side. Looks like a green car fuse. If that’s bad blown it can cause that code. Let us know. There is a YouTube video showing proper voltage limits step by step. Always been a issue with the Hayward systems. Good luck
JamesW
19,723
The GLX-PCB-MAIN is for the AquaLogic.
The GLX-PCB-PRO is for the Prologic.
What is the box model number from the front door?
bacevedo
148
Chandler, AZ
Thanks all for your replies. I'll take a look at the board but I'm thinking it may just be easier to get a new one instead of soldering, etc. Based on this being a known issue and the burning smell I suspect it's not the fuse and just needs a new board.
hklinker
5
Several years ago the same problem happened to me. Try Googling "No Cell Power". I found a website that gave detailed instructions on how to re-solder the bad connection on the K1 relay. It took me about 30 minutes and it was working again. I was so impressed by their support that I donated to their site. Two years ago, lightning hit my house and fried the board. It was over $500 on Amazon to replace the board, so I'd see if you can find the site. Here's my bookmark form 2011: http://www.nocellpower.com/
I'm not sure if it's still active as I could not get it to open. Here's another link to a web archive:
No Cell Power - Problem Solved!
Good luck!
bacevedo
148
Chandler, AZ
So I just installed a new board today and everything is up and running again. My neighbor/friend has his own pool service business and got me the board for $555 (including tax). It was basically the same price on Amazon with tax so I figured it would be better to go local in case there were problems with it. He mentioned Hayward is the one supplier that is hard to get cheaper than Amazon. Not sure why.
The install/transplant wasn't too bad, just had to label a few of the wires on the left side for the sensors and valves so I knew what went where. Took a lot of pics and went through the process in my mind a few times before pulling the wires off and the old board out. The new board came with a wiring layout so I knew which yellow wires and red/black/orange wires went where. The new board has version 4.46 firmware where my old board was 4.40. I can't find any info on what 4.46 has in it over 4.45.
The old board had a big scorch mark on the back in the upper right, behind the salt cell relay circuit. One of the yellow wires from the transformer was also scorched - the wire jacket was actually discolored black and had melted off at the connector, exposing wire that was starting to corrode. I snipped that off and put a new connector on and all is well with it.
I'm hoping this new board lasts a little longer. I have the panel shaded now, where as the first year or two it was in the sun, so maybe a little less AZ sun will help.
Still, in the end, the automation and chlorine generator are far easier and cheaper than having a pool service and getting all of the chlorine in manually. I'll take $550 every 6 years, plus the $400 for a salt cell every 3 or 4 years. That's still less than one year of pool service at $80 a month.
ETA: A couple of other notes I forgot to include in my original post.
  • When I first powered everything back on the pump was not working with the pro logic controller. It was turning itself on and priming. I had to use the controls on the pump itself and run through its setup to "resync" them. I didn't have to do that with my heater, which is a good thing. The control screen on my heater is out (known issue with hayward heaters) and I haven't bothered to replace it because I never control the heater through its own controls since it works fine with my panel.
  • I didn't have to relearn the wireless for the Aqua Pod. It just connected back up on its own. I'm not sure how they were synced up without reprogramming it.
  • Having to go through and set up every setting, timer, valve, etc. was a pain. I had spent a few hours going through every setting and documenting them in a word doc, so now at least I have that if anything goes wrong again, but using the Aqua Pod remote is so slow. But it's still better than sitting out in the sun at the panel. I'm looking to move to the Homenet remote because my Aqua Pod battery is out AGAIN. I'm not spending $400 for a remote that lasts 2 or 3 years and then is useless because you can't just change the battery. The phone app may not be any quicker, but at least I won't have to worry about replacing the "remote" again anytime soon and I can control things while away.
mknauss
30,848
Laughlin, NV
:goodjob:Good Job!
We are glad you have found our information helpful. Please, if you can, consider making a donation to TFP.
We are staffed by volunteers and are registered as an IRS 501 (c) (3) charity and donations are what keeps the forum operating without advertisements.
Support TFP!
mas985
13,584
Pleasanton, CA
One thing you might try is to run the salt level at the lower end of the salt range. I try to keep the salt level below 3000 and most of the time below 2900. This lowers the current and heat in the board and i believe can extend the life of the board.
bacevedo
148
Chandler, AZ
Thanks for the tip. My salt is a little high right now so I'll need to dump some water. I'm not sure what keeps making my salt levels go up. I'll start out around 3000, but then over time it creeps up to what is now, around 3500+. I don't know what's increasing the level. I must have some salt in my fill water. We do have very hard water, so maybe some of that hardness is salt or being read as salt by the cell.
KPM
Hi Everyone,
I am in need of a new PCB to repair the above shorted diode.
Amazon is asking me what model (PLPS8X288, I think) and series. How do I determine the exact model and series of my unit?
Thanks in advance,
KPM
Alan B
1
Oklahoma
I know this is an old thread. I just experienced this problem and decided to replace the board. When the component failed it melted one of the nylon posts that support the display unit. Anyone have a part # or know where another can be acquired? TYIA!!
