Programming - Pool Tone® 16 Color LED Pool Light
Ukiwis
95
California
Is there a way to add another lighting option in iAqualink?
There are 5 selections as follows.
I purchased Pool Tone® 16 Color LED Pool Lights for the pool and tub and they have different programs available.
Ideally I would like the controller prompts to match the options that are available. For example if I select the Pentair Intellibrite option above when I turn on the light I'm presented with the following selections...
The light modes I have with the Pool Tone® 16 Color LED Pool Light are
1. Evening Sea
2. Evening Rivers
3. Riviera
4. White. Neutral
5. Rainbow
6. River of Colors
7. Disco
8. Four Seasons
9. Party
10. White. Sun
11. Red
12. Green
13. Blue
14. Green-Blue
15 Red-Green
So, is there a way to edit the Pentair Intellibrite option above or even better to add a Sixth Button?
TIA
KIWI
16. Blue-Red
I just ran into this same problem. I tried all the options in iAqualink and none of them were compatible with pool tone. The pool tone has a feature (which I suspect the others don't) where it remembers what color/pattern it was on. Or the 'reset' logic is different. My workaround was to not treat this as a 'Pool Light'. Under "Colored Lights" I made sure that none of them were assigned to aux-1 (where my JandyWaterColor-piece-o-trash was previously). I then just relabeled that aux-1 as "Lamp" or something generic. Now in iAqualink, it's just a simple on-off toggle. Using the toggle on-off programming selection, I got the light to the color I wanted (99% of the time). Now it's that color when I turn it on every time. If I want to change colors, then I can toggle off/on quickly to cycle to the next program. It's not perfect, but it works. And in some sense it's better than the JandyWC program because I can just turn on the light and it's on the correct color. It doesn't have to cycle though 5 on/off patterns to get to the color I want every time.
Reactions: Ukiwis
