Our pool is just over a year old. We noticed splotching in our white quartz plaster within a couple months after startup (see attached pics). The pool builder, along with the plaster rep, didn't come out to look at it until 6 months after startup and told us it was hydration. They proposed doing an acid soak. After doing some research, including on TFP, I don't think this is the right approach. We had a company look at our pool, and they recommended draining the pool, acid rinsing and torching to get rid of the moister behind/in the plaster. I've also read on TFP that torching is not recommended, and the splotches can come back after acid wash and torching so I'm not feeling very confident in with this approach either, especially since it will cost $900 + cost to refill pool. I'm also concerned about the torching causing serious damage to the plaster. It seems that if the moister is going to be heated up with a torch, then it could expand into a steam behind the plaster and damage it, unless the plaster is porous enough to allow the steam to escape. However, I'm really not aware of any other solution. Please advise.
Michael
