- May 29, 2018
- 440
- Plaster
- Pureline Crystal Pure 60,000
I cannot seem to keep my TA, CH or CYA in check.
This spring we drained the pool, cleaned it and refilled.
Since then I cannot get TA in check, or CYA and CH up
Readings...
Temp 84
FC 6.0
CC 0
PH 7.6
TA 100 ( TA runs high but usually around 80)
CH 200
CYA 60
Salt 3700
CSI -.23/-.27
Early June we had the heater on and water temp was staying 88/92
This past weekend PH was 8.2 so I lowered to 7.6, turned the jets up to face the surface to aerate the water and we did alot of splashing for two days while swimming
In stages over the past 4 weeks, I have added 20 lbs of CYA, and 150 lbs of cal chloride
My plaster needs recoating , but thats another story
Should I tweak anything or are readings ok
Readings...
Temp 84
FC 6.0
CC 0
PH 7.6
CH 200
CYA 60
Salt 3700
CSI -.23/-.27
