We are helping our neighbors set up a used Intex type soft sided pool 16" x 4". Unfortunately there was no manual and the instructions we found online we have since discovered were wrong. The directions we used advised using a sand base but now that the pool is up and full of water we have found out that a sand base is NOT advised because it can be washed.out with heavy rain. Thankfully we were doing a poor job following those directions and probably only have an inch of sand down instead of 2-3 inches. All of the foot holds have a wood base under them and I think those are on solid ground because we had read somewhere that that was needed. Unfortunately the "solid ground" in our yard is actually compacted sand not real dirt. So I fear that is a problem too. Now we are hoping to find some sort of fix before it rains. I've read two things about using landscaping edging to try to prevent wash outs. One said to use it on the high side of the ground to divert water away from the pool. The other said to put it all around the pool with small holes that allow for slow drainage. Has anyone here tried either of those methods or have any other suggestions?! The neighbors will not be taking it down at this point so I'm just trying to help save it. I'll try to add a photo to this post as well. Thanks!
