The last year I was having less than expected pressure out the jets but everything seemed to work.
I am opening my pool now and I’m having issues with the skimmer or bottom drain.
I have this valve. I assume it is jets on one side and bottom drain on another, I am not sure where the skimmer falls into it, it seems it is linked with the drain. I got this pool when I bought the house. I have opened and closed it successfully for a few years.
Right now I can only fill the pump when it is in this position. This causes the jets to go but I see now suction in the skimmer. If I move it to open position (between the two) I lose power and the pump drains out. If I have it in this position and even crack it a little bit to the middle it loses pressure just as if I opened it all the way.
I think it is time to replace the grids but I can’t imagine it would cause this. The grids didn’t look bad when I cleaned them last year but they are somewhere between 5-10 years old.
I know when I close the pool and use the cyclone blower I move the level opposite to this position and that closes the main drain. In this position the jets work.
