Hi All --
It's been a cold spring in NH and I just opened the pool today. Everything looks good but I left my filter pressure gauge outside over the winter and it was leaking upon start-up. I replaced with a new one and all is good there i.e. no more leaking. I didn't check the pressure readout after installing the new gauge and starting up the pump. Wish I had done that.
Last year I would backflush at 20 PSI and my filter would return to 12 PSI after the backflush. I just noticed this filter was running at 20 PSI after shocking and running it for a few hours. I just backwashed for a solid 5 minutes but it only dropped the pressure to 18 PSI. I've confirmed there is nothing I can see that is wrong. (baskets clear, valves open, etc.)
Is it possible I got a bad gauge or is some other problem more likely? Not sure what to do here to troubleshoot.
