I have a Proline sand filter and 1 HP pump running my 10k gallon above ground pool. When the pump is first turned on, the pressure at the return jet is strong. The gauge reads between 10-15 PSI. After an hour or so, the pressure at the return jet begins decreasing dramatically while the gauge still reads 10-15 PSI.
I've backwashed 2-3 times recently. The skimmer and pump baskets are clear, as well as the pump impeller.
My only guess is that there is an air leak somewhere before the pump. Could the ball valve be leaking? I should also point out that when my electrician was hooking up the ground to the outside of the skimmer, he accidentally drilled the hole for the screw in the wrong location. We plugged it up with rubber and silicone and it has never leaked water. Could this be where the air leak is?
I'm at a loss and appreciate any advice.
