I opened my pool for the first time after two full seasons covered, and as you may imagine it's a green mess. I've taken some time to read through Pool School, got my TF-100 Test Kit and ran some numbers through Pool Math, as I am ready to SLAM the pool, but wanted to get some input from the experts here at TFP before I get started.
Current numbers (20,000 gallon vinyl lined pool, 48 sq ft DE filter):
CYA < 20 ppm ... FC = 0 ... pH = 6.8 ... TA = 90 ppm ... CH = 200 ppm
For a SLAM, I think I need to get the FC up to 12 (shock level) - so my targets will be as follows:
CYA ~ 35 ppm ... FC = 12 ... pH = 7.5 ... TA ~ 100 ppm ... CH = 200 ppm (I think my Calcium hardness is within range?)
PoolMath returns the following:
2 gallons 1.5 qts 10% chlorine to achieve shock level of FC ... 6 lbs. 11 oz. washing soda to raise pH ... 2 lbs. 15 oz. baking soda* to raise TA ... 2 lbs. 8 oz. stabilizer to raise CYA
* since the baking soda will also raise the pH, should I compensate by adjusting the amount of washing soda, or vice-versa?
My understanding is that I need to get the pH and TA to the target numbers before I start dumping in the chlorine (I'll be using 10% liquid chlorine from WalMart). Is there a sequence I should follow, or should I add the recommended amounts all at once?
I'm also concerned that I will need (very) frequent back washing since there is a lot of algae - I've tried to get as much crud off the bottom as I can, but since I can't see the bottom I can't be sure that I got it all. I was running the filter in "recirculate" before I got the test kit, as I found the filter was clogging within minutes with all the algae and no chlorine. I think the "formula" for back washing is to add 75% of DE capacity for each "cycle" (three pounds in my case) - this could get pricey
- At this rate I'm concerned that I will have to be prepared to backwash every 15 minutes??? I should probably pick up a new box of DE.
I have found this site an invaluable resource and look forward to getting in the pool for the first time in two years! Thanks in advance...
