I wanted to find out what the experts here think about when you should run your pump for max benefits. I had been running mine at night to save electricity and I also thought the lower night temps would make it work less hard or over heat, but then I read it's best to run it during the day when the temps are the highest to avoid algae because the chlorine burns off faster when it's not circulating. I also read to run the pump 1 hr for every 10 degrees outside temperature too. It's going to reach 110 degrees here in AZ in a day or so I'm trying to get everything up to par now. So that would mean I need to run it 11 hrs and during the day too to get the most benefit out of my chlorine. Is this information correct?
