- May 3, 2014
- 62,897
- Fiberglass
- Pentair Intellichlor IC-40
In your area, I would budget for twice that, and then be surprised if less.
You'll want to bring down your TA. Adding acid lowers your pH and TA. High TA will cause your pH to rise quickly. Aeration expedites pH rise. When pH level gets to 7.8, add enough MA to bring it down to 7.2. repeat the process until your TA is forced down to range. Then adjust your numbers and monitor CSI. Keeping CSI between -0.30 and 0.0 will help mitigate scaling.
To aerate, use your spa spillover. Set the valves you get good flow from the spa to the pool. You don't mention what your CYA is. Make sure you don't allow FC levels to drop below the minimum FC for you CYA level according to the FC/CYA Levels. Set up your SWG for a gain of about 4 ppm for day. Chances are you'll lose 3 to 4 ppm per day this time of year.
The TA of your fill water plays a role in how quickly your TA will rise or drop. You can test it if you wish. I assume you did not add MA during your SLAMagranza, which would explain why your TA has not dropped.
As long as you let your TA and pH ride a bit high for awhile, evaporation will raise your CH by 75ppm or so by the end of this swim season.
See what the CSI is. Keep it above -0.3
