Hello,
I will be purchasing a 315 gallon hot tub that will have an ozonator which I am reading could be a problem for chlorine.
I know first thing I have to do is fill and drain with some Ahh-Some.
Do I have to fill completely for this? I read in some other forums just the foothold is enough but I am unsure.
For the most part I got most of my information for chemicals from the chlorine sticky. I will be buying a Taylor kit along with FC strips, but I am still iffy on some parts such as starting from the beginning.
PH 7.2 - 7.8 with the use of Muriactic acid and baking soda to regulate
TA 50 I've read 50 is the magic number here and I believe I would be using 20 mule team borax (acts as a buffer as well)
CH 120 - 150 PPM I will be using Calcium Chloride Pellets
CYA 20-30 PPM I will be following the sticky and will be using a Cyanuric Acid Stabilizer or Chlorinating Granules till 30 PPM and switch to a bleach (Please let me know you preference for this need)
FC 3 - 6 PPM - I will be testing for this daily and adding bleach per use, what concentration is prefer for this? (I saw one person recommend 6%)
Is there a certain order to do these things in for a first time fill and ever fill after?
Will the ozonator have a negative affect on the hot tub since I am not going the bromine route?
I've read on some reddit posts that I should only add CH and Borate once per drain, is there any truth to this?
Also, on reddit posts I seen many people swear by aqua finesse but I hardly read any posts on here about that, is it worth looking into?
Please let me know if I am missing any chemicals or if any of the chemicals I listed has an negative affect such as bad residue and you have an alternative instead.
J
J
