Probably. Evidentally from deep in the plumbing. I'd buy another tub of ahhsome and run 2 more cycles as directed. It appears to have found the gunk we were looking for.Just run of the mill algae?
What else am I supposed to do today ? WORK ????????I don’t need a response, just posting for others who may have found their way here
These are pics from last years wwm battle after using ahhsomeIt's pretty hard to argue against what the ahhsome produced after all this time
That's one (arguably the only one) that won't hurt anything if added to the skimmer.I’m sure you guys have advised against adding things to the skimmer.
I don't.Long as you don’t see any harm in it
At some point, and sadly I'm not psychic or I'd be playing lotto for a living, you will have erased all proof of the pre-tfp days and it'll only be tfp going forward. No idea if it's 2 or 22 tho.I would be willing to use it once a month
Whether or not you see it, you have a vortex going on. I often see beetles or small debris taking laps when it looks like the water is still. Your gunk is evidentally sticky so it's latching onto the skimmer like sunblock or such would.I am scratching my head a little as to why it’s gathering around the skimmer “bowl” and not going into the sock?
Yeah. 3.1 is just silly.do I count 1 qt 12.5% Lc as raising fc by 3?
You can order directly from their website ahhsome.comHe said I can do it right away.
I’ll check Amazon because the closest retailer is 50 min one way. I had trouble trying to order it on Amazon before. I’ll drive up there Monday if Amazon is a no go
I believe the ahhsome (or gunk it loosens) may contribute to a higher fc demand for a bit .The pool did have a lot of use yesterday
8 ppl for 3ish hours
