So, I have a new Pentair SuperFlo VS pump. We were originally going to wire it to our existing 115v power that the old pump was hooked to.
After some research though we decided instead to run a brand new 230 line from our main box to the pump's location. The manual recomends/suggests a Pentair PA220GF 20 Amp 2 pole GFCI breaker. However our main box is an older Square D. So initially we cleared a double spot on our breaker panel to install an equivalent Square D breaker. We want to rewire the garage at some point so my father in-law installed a new Eaton brand box in the garage near the pump location, put a 40 amp breaker in the main box, and ran the new line from the 40 amp breaker to the new box in the garage. Finding an equivalent Eaton a 20 amp 2 pole GFI that will fit that box has been a challenge. So now we're looking at possibly finding a 20 amp 2 pole GFCI breaker that is equivalent to what the manual recommends and then get whatever box we need for that breaker.
I thought I'd post here and see if anyone has a recommendation and has this particular pump?
