Hello,
This will be my first time using a softub 220 outdoors over winter. I'm sort of close to chicago and we can have mild winters or it can be -20 F every night for weeks. I'm sure the tub can handle that but I had a few more questions.
What if we have a power outage that lasts for days? I'm going to experiment and see how well the tub can maintain the heat without running. I'm concerned that with a softub the pump sits outside of it. I wonder how likely it would be that the pump would freeze up first or the short connection going to the tub? Maybe I could wrap some blankets around the pump and connection. If I had some sort of pump failure I would just quickly drain the thing with a sump and roll it inside until I could dry it out and repair.
I've also considered just draining the tub over the winter for practical reasons. The pump I could remove and store in my basement. The rest of the tub should be easy to get most of the water out of the lines. The plumbing is also pex so it should be somewhat resistant to freeze damage if a little is left? I hear tubs can be a lot of fun in the winter but maintenance will be more of a chore. No hose and you still need to go out and check it all the time. Do you guys fill up buckets of water in the house to top it off? I had a idea of scooping a few buckets of water and trading it for fresh stuff to delay a refill.
thanks
thanks
