Possible to Only replace the body of the skimmer on AGP?
callie_grace
68
#1
Looks like part of my skimmer cracked over the winter. Do you think it’s possible to replace only the body of the skimmer? Below I have attached pictures of the cracks in the skimmer and the skimmer parts list. I believe it looks like I would be able to replace the back half without messing with the liner. What do you all think?
azide999
103
Kingston, TN
#2
This one looks a bit tough. I would have suggested some form of adhesive applied inside and out, but the cracks are at critical points which may leak with repair. Sometimes buying a whole new skimmer is less expensive than a couple of parts, but it does not mean you have to use all of the new skimmer (assuming it is the same or similarly configured model), and you will have a few spare parts including a weir and return for future use.
Disclaimer- I have never replaced a skimmer without a liner because they both happened to be needed to be done at the same time.
I would suggest first filling the pool to about 1" of the skimmer faceplate to minimise potential liner movement.
My guess is you fear that if you remove the faceplate the liner will drop, and what you are wanting to do is keep the faceplate, gasket, liner and screws in place while attaching a new skimmer body and outside gasket. Of course, in this case you will have to back out the screws bit by bit each in turn while someone else pulls the cracked skimmer body out gradually. Similarly when installing the new skimmer body the faceplate would have to be pressed against the pool wall while the screws are each in turn screwed bit by bit into the new body. It may help to gorilla tape around the face plate (part on the face plate and on line) while doing this to assist in the liner being held in position - however, I do not know if the liner will hold up to gorilla tape removal or if residue will be left behind.
One problem might be that the pool side gasket might need to be replaced because gaskets are generally single use. You might screw the assembly tighter this time.
However, if the pool level is close (an inch or two) to the skimmer face plate, you might test to see if the liner stays in place at the skimmer so that you can replace the whole assembly. I suspect that this will be the case.
CJadamec
2,192
Quaker Hill, CT
#3
Before replacing the skimmer you might want to try an epoxy putty or polyurethane caulking repair. There is virtually no pressure on that joint so the seal doesn't have to be that strong.
One of the many brands of pipe sealing tape might be worth a try as well.
Depending on how old or how tightly your liner is stretched around the skimmer opening you could be in for a lot of hassle getting a new skimmer in.
Jamison04
686
Tecumseh, OK
#5
If you have a wide mouth skimmer than yes it is possible to order just the back portion and replace it with out having to deal with removing the front half that is attached to the pool wall.
Finding the part you need for the right price might be challenging. Might be cheaper to just order a whole assembly and just use what you need and save the other parts.
PoolguyinCT
In The Industry
Jul 21, 2014
2,673
Connecticut
#7
Agreed. Or even trim pipes to use a fernco/mission clamp..
Btw - CJademec, I didn’t know you were a CT nutmegging yankee too.
callie_grace
68
#8
Thank you all for your help! I think I am going to start off with the putty and hopefully replace the back half either later this season or next year.
JoeSelf
444
Glassboro NJ
#9
I have done this before and it is not hard at all. Make sure you get a new gasket with the skimmer for between the widemouth and skimmer. It should also come with new S.S. screws.
JEC11718
100
Panama City
#11
I would just replace it. Amazon sells the entire thing with all the parts and then youll have spares. fixing it with epoxy will just delay the inevitable. i installed one with a full pool and it was a frame pool last year!
PoolguyinCT
In The Industry
Jul 21, 2014
2,673
Connecticut
#12
Born and raised down in the southeast corner right on the sound. Traveled a few places but keep on ending up back here.
NYC native (too young to remember) grew up in southington, now in Plymouth, moving to burlington or back to southington soon.
& yes next house must have existing Inground pool, so we get the pool for free. [emoji41]
