Yesterday, I tested our AGP and discovered that the FC had mysteriously dropped to 1.5 and then realized that our over-the-edge SWG had stopped working -- I guess I should have been paying more attention. :-/
pH was 7.6, TA was 60, and CYA was 60. Based on the low FC, I assumed a high risk of algae and took action as soon as I could.
That evening, I bought and added 6 gallons of 6% bleach (WalMart brand Cleaning Bleach), which I calculate should have added 24.5 of FC, but I didn't verify that after adding. This morning, I checked it and surprisingly found it to be at 27, which would suggest some slight inaccuracy in testing, no FC loss during the day (it was cloudy) and basically no overnight FC loss? That doesn't add up to me.
I wasn't able to devote any time to it today other than testing (this pesky thing called "work" got in the way). This evening, I tested again after a mostly-cloudy day, and FC was down to 14.5.
A few questions/concerns:
1. Does FC drop more quickly in ppm when it starts higher (in other words, is FC drop more of a percentage or is it used up in ppm based on sun and organic matter?) I am guessing it's the ppm and that the drop of 12.5 today is due to algae, in spite of the pool appearing crystal clear.
2. We're getting ready to go on vacation Friday, so I don't have time to get a new SWG (I want a proper in-line one this time). We have a neighbor who is willing to check the skimmer basket and start the pool for us every night on a timer, and we can probably twist her arm to add bleach for us too. But testing the FC level would be asking too much of her, we feel. So we'd be shooting in the dark and also unable to vacuum/brush regularly.
3. Is there a benefit in going ABOVE shock level to compensate for the fact that we don't know how much it will lose daily and can't vacuum/brush? If so, what level is safe before we risk corroding the pump/filter or deteriorating the pool itself? Would raising CYA level a little help?
Tomorrow, I can spend more time monitoring and maintaining shock level, vacuuming, and brushing, but I fear that my efforts will be in vain when I leave the next day.
Any guidance on how best to tackle this to either eradicate the algae, or at least minimize the impact while we're gone -- would be MOST appreciated.
Thank you!
Thank you!
