My in-ground pool with DE filter and fairly new variable speed pump has always run with a pretty high back pressure (30PSI) and has had mild green algae problems (brush the walls weekly) for the last couple summers. When suction got a little low (judged by slow crawler) I'd backwash a little, not always topping up the DE every time. This worked OK for a couple seasons. (I keep lots of Cl in there and the chemistry checks out OK.)
Lately the algae was building up faster (odd in the cooler temps), the pressure was heading up to 35PSI and backwashing didn't help the crawler much. Never had this before.
I thought (confirmed at the local pool shop) that my filter must be clogged with algae so I took the filter apart and cleaned it pretty good. But this didn't change a thing. 35PSI, hardly any suction.
Switching between skimmer, crawler, and spa I can see there is no input clog. Doesn't seem to be air in the DE filter tank when it's running. I can switch output to pool or spa and that doesn't change anything.
What am I left with? Some clog after the filter (pipes go through a heater) but before the pool/spa split? Something with the pump? (I haven't messed with it but I doubt it's seen much debris.)
Ideas anyone?
Ideas anyone?
