PoolMath - time zone?
jessman1128
47
Galesburg, MI
I just discovered that my PoolMath logs are accessible online through my profile, but the time entries are off by 4 hours! e.g. my log entry from 8:38 AM Eastern time this morning is showing on the web as 12:38 PM! What's going on here? PoolMath Logs
frogabog
2,833
Portland, Oregon
I'm having an issue with time as well, although it appears that I'm 12 hours off. When I click into my logs from my computer it says I'm a 4:45am backwasher. I assure you I was not! Pool Math zip code is correct and shows the correct time in the app, and the forum is set to UTC 8 Pacific Time which is also correct. I did change that on the forum last week because it was set to a random caribbean island or something similar. FYI, for your debugging info.
Leebo
Admin
10,145
Eastern Ohio
This bug only should be seen when viewing your logs on TFP. It’s an issue where logs aren’t converted to your time zone however is displayed in Universal Time. All logs are saved in UTC and converted on your app but for whatever reason it’s not changing correctly on the net.
Reactions: frogabog
