Is it possible to change the CSI target range in the PoolMatch App (IOS)? I'm able to adjust everything else, just not CSI. Ideally, I'd like to tighten it up a little, like -0.3 to 0.3.
Yep, I know the value itself is computed automatically. I'd just like to adjust the target range.Pretty sure that result is dependent upon your water chemistry, and temperature. You can't tighten it up, it's a computed result.
Tighten it up by adjusting your water chemistry.
Can you adjust the CSI target range in the Classic version? I've tried it, but I'm not seeing that as an option. It's not critical I guess, but I'd like to my "red flag" go up before my CSI reaches +/- 0.6. And since the app allows for manual adjustment of all the other target ranges, I figure it might be an easy fix.You might have to work with Classic Pool Math as noted beloved.
Same as Pool Math, except the forebearer of Pool Math.
Since it's a calculation, there's no way to put it in as a target. There's many different ways you could change your CSI - pH, TA, CH, CYA, even temperature all play a role. If you put in a new "target", how would the system know which of these to make you change?
What using the web version / classic lets you do is type in some numbers to see how it would change your CSI. "If I drop my pH to 7.2 and my TA by 20ppm, what does that do to my CSI?" sort of thing.
Yep, thanksYou can do the same What If on the app. + then LOG then TEST RESULTS. Put in any numbers you want to try. The CSI is recalculated at the bottom. When you are done X out of the screen and don’t save it.
I think the OP wants to change when warning messages come up for CSI over -0.6 right now.
I appreciate that...although I don't know Java, haha!! Either way, what i'm really looking for is a way to do it on the app because I have my phone with me when I test the chem levels and I like to immediately log everything and track changes. Thanks thoughThe one on here is JavaScript and if you have a home server, like I do, just copy the script and load it into your server. You can then edit the code if you like assuming you know JavaScript.
Java and JavaScript aren't the same. ?I appreciate that...although I don't know Java, haha!! Either way, what i'm really looking for is a way to do it on the app because I have my phone with me when I test the chem levels and I like to immediately log everything and track changes. Thanks though![]()
Just a notification...not even an actual alert or anything like that. Just a quick-look range that I can glance at and know, if I'm not within the parameters, I should take a closer look at my pH/TA/CH.Are you just looking for it to notify you when you're out of range, or to put in a target and then have it tell you what chems to add to the pool to reach the target?
Thanks, that's helpful to know... and I think it's more important to keep a log in order to track changes and trends (rather than make immediate changes if the CSI is off).Problems with CSI being out of recommend range take months to manifest themselves. Short term excursions in CSI are to be expected. You will have plenty of time to stay ahead of things with the default targets.
