- Nov 5, 2008
- 2,598
Wiithout stuff that splashes,kids,fountains, the pH will be slower to drift upwards, but when it does, just adjust back to 7.5 or 7.2 with the dry acid you have (pH down). You can save a few $ by getting muriatic acid but it does the same thing. Calculator handles that, you see.mcelaine said:I don't have any kids! Should I be canvasing the neighborhood! :-D Just my daughter (she just turned 30) and myself on a couple of floats reading a book!
Wally has been running around stirring things up. I had to chase him and make him come to the end of the pool. I'm thinking he may need a couple more lengths of hose attached to him. We let him swim all night and he doesn't like the end closest to the house.
Do always let the pool mix before collecting a sample for testing, then take your sample from elbow deep in the pool. An hour of filtration is generally enough, tho I guess a good brushing with the Wally Whale brush is just as good.
So, you seem to have it under control. Acid to adjust pH to stay in range, knowing that TA trends to drive that up and the acid you use corrects that TA level over time. Chlorine will be kept in range with daily testing and additions as needed. And you did fix the CYA already ? (hard to read back too far from my phone )
