My pool was perfect until my toddler grandson swam in it, so I know what he did in my pool on Saturday!
Thursday, my pH was at 8.2 so I can't swim in it until it goes lower.
Since the pool is in direct sunlight from sunrise to about 5:00 p.m. and half the pool is shaded after 5:00 p.m., I thought I would raise the CYA to 50 or 60. Water was cold on Saturday, but is now a lot warmer.
1. Since adding stabilizer lowers pH, does that mean I have to wait a week for the CYA test to test accurately? Does the pH lower every day, or do I need to wait a week before swimming? Pump runs 24/7.
2. I used the pool math calculator and put in the required amount of Muratic Acid Thursday morning, but today, 24 hours later, the pH is still at 8.2. How long should it take to lower the pH? Pump runs 24/7. pH seems to be the only problem. Is urine responsible for raising the pH? It was 7.8 on last Saturday.
3. I know my Phenol Red is from last year, so I will be ordering new today. If the chemical is old, which way would the pH test be skewed? Would it show higher or lower on the pH chart? Could it be a false high pH? Or would it more likely show a false low pH?
4. Is there any reason to order a new yellow lid bottle of chemical to do the chlorine test? I usually do FC test instead. Any reason to do both?
TA = 80
CYA = 35 (might change it to 50 or 60)
pH = 8.2 (at least the color matches the container's chart. Not sure how high it really is)
FC = 9 this morning (I added chlorine last night based on pool math, but I forgot to test again a couple of hours after adding it. Will do OCLT tonight.)
CC = 0
thanks for any advice.
TA = 80
CC = 0
