Recently installing an above ground pool, I checked everything and it looked correct, until I started filling it, I have about 8 inches of water and the walls at the top started to bend it, not sure if the liner is too tight or maybe another issue, any advice is appreciated.
How warm was it when you began to fill the pool? Did you unfold the liner and allow it to sit in the sun for a couple of hours before you installed it in the pool?
