Im in the process of changing the liner of my inground pool. I pulled the liner out and noticed that the where the skimmer and pool wall meet is corroded. I took the pictures before I pull off the old gasket. The rot has went passed some of the screw holes.
How should I go about repairing this?
Should I patch over with sheet metal and cut out a new hole for the skimmer in the same place?
Should I patch up the hole and move the skimmer to a different part of the pool?
or something else?
It appears that the cause if the the concrete deck has shifted forward right above the skimmer which has probably caused the leak resulting in the rust.
or something else?
