I have two inermatic timers one for my pool and one for cleaner that i no longer use.
So i have noticed a few times that the pool pump is running when it should be off and when I check the manual switch is in the on position. Also noticed that when the timer turns pump off I cannot flip the manual switch to on until some time passes and the dial moves.
Is it possible for the timer to flip the manual into the on position? I suspected someone was jumping the fence to use the pool but it would be fairly bold of them to turn on the pool pump on.
Going to lock the box but wondering if I have a bad timer maybe?
-David
-David
