Pool temp sensor
Assuming you have the new sensor, (you should confirm with your temperature sensor kit, it is a 3/8" for the new sensors). Just drill with medium speed and medium pressure.
Is this a replacement or new? Likely should be between the pump and filter...confirm placement with instructions for you kit.
If you are nervous about the drilling process, make some practice holes in a scrap piece of the same sort of pipe. That will let you get a feel for the process and confirm you got the correct fit. That's what I did before drilling to find my flow meter. If you have a sharp drill bit, pvc drills quite easily an nicely.
